Go Back   Club NA-T Forums Turbo Boost HP Car >
Specialized Forums
> [Archive Only] XSPower
Register FAQ Locate Members! Members List Calendar Mark Forums Read
Thread Tools Display Modes
Old 12-22-2011, 05:46 AM   #811
Importsnrice
2 psi
Importsnrice's Avatar
Trader Ratings: (0)
Quote:
Originally Posted by Importsnrice View Post
How much for just at turbo?
My friend was wondering how much it would be for just the T61 or T67 T4 turbo that comes with the kit. And if you even sell just the turbo? Let me know thanks
__________________
1994 Toyota Supra:
-XSPower T61 @ 336WHP 8PSI
-Stock fuel, HG, ignition, etc.
1993 Honda Prelude:
Just an intake untuned VAFC 151WHP@2900lbs runnin' 15's flat!!
2001 Infiniti I30:
Bone stock DD/Winter Car. Hopin' to get into 15's with it.
1995 Eagle Talon TSi AWD:
Stock 5 speed except free mods. Winter car
Contact at Facebook.com/importsnrice or Importsnrice@yahoo.com for any questions or advice!
Offline:
Old 12-29-2011, 02:03 AM   #812
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
send me an email at mark@clubna-t.com and I'll get you the price, with shipping.
__________________
paypal & email: mark@clubna-t.com
email is the fastest way to get me.
Offline:
1JZ Kit output?
Old 02-07-2012, 01:53 PM   #813
Gotzy
in vacuum
Trader Ratings: (0)
1JZ Kit output?
Hi, could you provide the power expectations for your base kit and the optioned up kit with the GT35R please? I understand there will be variables so an approximate range will suffice.
Thanks
Stephen
1JZ kits ** $1749 Shipped **
T60 T3/T4 Hybrid turbocharger (.75AR Hot .82AR Cold, compressor: 4" inlet, 2.5" out Turbine: T3 in and 3" V-Band Out - no welding required)
**OR**
GT35R turbo (+$290)
12x24x3" polished aluminum front mount intercooler (optional sizes available)
1JZpolished stainless steel manifold
40mm wastegate - compare to HKS
polished stainless steel dump tube
Choice of blow off valves, compare to Turbo XS -OR- Blitz
** or upgrade to 50mm V-Band mount BOV - RED, BLUE or clear anodize $40 extra - compare to Ti-Al
** or upgrade to sequential style $30 extra - compare to HKS
4" polished stainless intake tube
3" v-band clamp kit
3" v-Band polished stainless down pipe with 02 bungs
Teflon and SS braided oil supply line, high temp drain lines & flanges
gaskets
turbo oil return plate (to oil pan)
Offline:
Old 02-08-2012, 08:04 PM   #814
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
Generally, the 1JZ kit with the GT35R puts down 510WHP at 24psi.
__________________
Offline:
Old 02-29-2012, 05:31 PM   #815
Bboy_Trevstuh
I needz TuRbo!!!
Trader Ratings: (0)
So everything besides intercooler piping and some time of unit to control fuel and all come with the kit?
__________________
Stock for now!
Offline:
Old 03-02-2012, 10:59 AM   #816
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
Yes.....Email me at mark@clubna-t.com and I'll put together a kit for you at a great price.
__________________
Offline:
how to order the kit
Old 03-18-2012, 05:56 AM   #817
nayabis25
in vacuum
Trader Ratings: (0)
im just wondering how to order the kit and how much would it cost to ship the kit to hawaii? i want my IS300 turbo already.
Offline:
Old 03-18-2012, 05:58 AM   #818
nayabis25
in vacuum
Trader Ratings: (0)
just wondering, what the website so i can order the kit for my IS300? and how much will it cost me to ship it to hawaii?
Offline:
Old 03-18-2012, 06:16 PM   #819
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
Hi nayabis25, is that the FFIM kit your the turbo kit you're interested in?
__________________
Offline:
scrappy1s2
Old 03-27-2012, 11:07 PM   #820
scrappy1s2
in vacuum
Trader Ratings: (0)
scrappy1s2
Quote:
Originally Posted by 98mkiv View Post
you need to do a little more looking before you tear into the bottom end. I've seen more harm done than good by going to deep without a good reason. You may just have a seal that is not seating well.
Do the compression test several times and also do a leak down test. I'd be surprized if you had rings that were that bad on just ONE cylinder.
Maybe, but I'd be surprized.
Anything thicker than a 2.0 HG is TOO thick and you will not only lose power down low, but you will wind up having to make rediculous boost just to make some power up top. I like to keep the compression higher than 8.8:1 - and that's the min I would go. That's why I suggest the 1.3mm HG set I sell.... good low end compression power and still safe to boost up on pump gas to >17psi.
well if i have had my head shaved to the max before would you recommend going with the 3.0 HG then or still stay with the 2.0 im new to the forum so let me i own 93 toyota supra 2jzge
Offline:
Old 03-28-2012, 09:49 PM   #821
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
what do you mean had your head shaved to the max? how much did you have it milled? That's pretty unusual.
__________________
Offline:
Old 06-03-2012, 03:19 AM   #822
Naybad
in vacuum
Trader Ratings: (0)
Hi i live in the Uk and am looking at a NA supra manual (2jz gt) and was considering a turbo kit. I would like to know what the cost off a turbo kit (Delivered with tax ect) with everything that i need would be ???? I am presuming i will need management as well and what sort of power can i expect with just a bolt on kit ??
Thx Craig
Offline:
Old 06-09-2012, 08:12 AM   #823
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
Please email me directly at mark@clubna-t.com
__________________
Offline:
Old 06-09-2012, 02:26 PM   #824
98Quicksilver
in vacuum
Trader Ratings: (0)
I sent you an email and never got a response. I was wondering about getting a ball bearing turbo by itself for a kit i just ordered else where. I wanted to order this kit but never got a response.
Offline:
Old 08-09-2012, 08:27 PM   #825
psisc
2 psi
Trader Ratings: (0)
What springs will work in wastegate to rasie boost?on the hks style
Offline:
Old 08-13-2012, 07:12 PM   #826
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
Yes, HKS
__________________
Offline:
Old 09-11-2012, 10:29 AM   #827
AznBikerBoi
in vacuum
Trader Ratings: (0)
Has anyone, or does anyone know of this kit being fitted to a JZS161 aristo?
Mark would you be able to assemble a kit to suit, if so is pricing still the same?
Offline:
Old 10-01-2012, 08:58 PM   #828
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
yes, no problem, email me direct at mark@clubna-t.com
__________________
Offline:
Old 10-11-2012, 09:10 PM   #829
95mkivT
in vacuum
Trader Ratings: (0)
Just ordered the kit today thanks mark!
Offline:
Old 11-08-2012, 09:27 PM   #830
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
no, thank you!
__________________
Offline:
Old 01-13-2013, 12:02 AM   #831
boosted516
in vacuum
Trader Ratings: (0)
can i buy a kit without the turbo, bov and wastegate? also do you have a website? thanks
Offline:
Old 01-13-2013, 10:54 AM   #832
98mkiv
Leaded Gas Admin
98mkiv's Avatar
Trader Ratings: (4)
this is the website, and yes, I can customize for you.
__________________
Offline:
Old 01-13-2013, 01:13 PM   #833
boosted516
in vacuum
Trader Ratings: (0)
pm me a price
Offline:
Old 03-09-2013, 06:39 PM   #834
alvarez0
in vacuum
Trader Ratings: (0)
how much for downpipe and midpipe and turbo mani pm price thanks
Offline:
Old 03-18-2013, 09:28 PM   #835
BuffNStuff
in vacuum
BuffNStuff's Avatar
Trader Ratings: (0)
Is this place dead or something? I can't seem to get a reply to save my life lol. I PM'd you and sent you an email regarding a single turbo kit for my 1997 sc300 auto. Looking forward to hearing from you soon, as I am sick of my car being a slow pig. My roommates Sierra 1500 just walked on me the other day, and he has no mechanical know-how. As a car enthusiast, this is the worst feeling ever. PLEASE HURRY!!
__________________
1997 Lexus SC300-45,xxx miles Bone stock. Auto
1996 Pontiac Trans Am Ws6- Bolt ons- 13.4@103 (SOLD)
1984 Buick Grand National-Bone Stock- Stolen.
Offline:
Old 03-20-2013, 09:53 PM   #836
BuffNStuff
in vacuum
BuffNStuff's Avatar
Trader Ratings: (0)
Still nothing.
__________________
Offline:
Old 04-23-2013, 12:39 AM   #837
BuffNStuff
in vacuum
BuffNStuff's Avatar
Trader Ratings: (0)
went with a different kit because I never got a response...
__________________
Offline:
Old 04-23-2013, 01:28 AM   #838
california-plating
in vacuum
Trader Ratings: (0)
Quote:
What not did you go with? I'm on the same boat
Offline:
Old 04-24-2013, 11:29 PM   #839
sj408
in vacuum
Trader Ratings: (0)
Pretty sure these kits are being sold on ebay still for 1100 or so.
Offline:
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsors: Boston Colocation + Boston VPS
